iR3320
  • copicatt
    • Nov 2008
    • 366
    iR3320
    Customer has faint lines (lead to trail) when printing only. Doesnt happen on copies. they are 1/4 to 1/2 inch apart she says.....happens from more than all PC"s. Ideas? they are a good 1.5 hrs from here.
  • teckat
    • 16083
    Re: iR3320
    print driver being used
    what applications used to print from ?
    • copicatt
      • Nov 2008
      • 366
      Re: iR3320
      Not for sure of the driver used, but it is installed per PC and not to one and then shared. And I told wrong, it is Front to Rear. Don't know why I said lead to trail.
      • teckat
        • 16083
        Re: iR3320
        cross-feed or called MAIN SCAN
        I know the PDL KIT is standard on 3320/2220
        are they using PS or PCL or both ?
        is this from any certain application
        • copicatt
          • Nov 2008
          • 366
          Re: iR3320
          Yea, crossfeed. 20 years, never heard that. Go figure.
          • copicatt
            • Nov 2008
            • 366
            Re: iR3320
            had her print a report internally, says it also contains the lines.....but not on copy. WEIRD
            • teckat
              • 16083
              Re: iR3320
              Have her print out a word doc & a pdf -- with differant drivers from PC
              • copicatt
                • Nov 2008
                • 366
                Re: iR3320
                when I say internal report, I mean, at the copier. Had her go to add functions....report settings....print list....network.......report has lines....so don't believe now it is PC related. I'm gonna go out there mon morning and see what I can find out.
                • teckat
                  • 16083
                  Re: iR3320
                  I see now
                  so internal test & pc prints have black lines
                  glass copy has no issue
                  • copicatt
                    • Nov 2008
                    • 366
                    Re: iR3320
                    I see now
                    Correct.
                    • Brian8506
                      • 1665
                      Re: iR3320
                      But you haven't been there yet to physically confirm this?
                      • copicatt
                        • Nov 2008
                        • 366
                        Re: iR3320
                        Heading out there mon am. I realize she could be mistaken. I've had her test different methods whilst on the phone. It is a good drive so was getting a little input before I go....my first thought was the printer was printing from LTR drawer and copying from LTRr and streaks were on the edge but she says it ain't so and it covers the whole page....I will update .....
                        • teckat
                          • 16083
                          Re: iR3320
                          ______
                          In the error of smartphones_-_(if u have one & customer has one)
                          U tell them to take pics ,& send them over to u __when distance is an issue
                          • DAG COPIERS & COMPUTERS
                            • Oct 2010
                            • 860
                            Re: iR3320
                            ______
                            Very true teckat, you save a lot of resources by doing that.
                            • copicatt
                              • Nov 2008
                              • 366
                              Re: iR3320
                              I have been to the customer and confirmed what she said....printouts have cross feed faint lines and actually some shading on the trail edge. The copies are clear. Printing an internal report.....fax data, etc has the lines....not on copies.....do a Dcon clear??
