iR 3045 Finisher
  • lionex3d
    • Jun 2013
    • 41
    iR 3045 Finisher
    what is the procedure for RAM initialization for the iR 3045 finisher. Thanks
  • Brian8506
    • 1664
    Re: iR 3045 Finisher
    What trouble are you having?
    • lionex3d
      • Jun 2013
      • 41
      actually it's just for information
      I was doing a iRC2880i Finisher-Z1
      while reading the service manual, found that the controller PCB can be ram initialized
      so I was wondering if the 3035/45 series finisher can also be ram initialized.
      • its_just_a_copier
        • May 2011
        • 132
        Error :
        For various error codes and malfunctions. If you suspect that the Finisher Controller PCB may need to be replaced, try the following to reset and clear the memory of the Finisher Controller PCB .
        Workaround :
        With the copier "ON' turn ON all 4 dip switches, cheat the finisher door switch, press and hold SW2 until the LED stops flashing. Then turn off copier, turn off dip switches and turn copier back on. Check to see if the finisher initializes and if the problem is resolved.
