IR 5020 Hard Drive Replacement
  • yormets
    • May 2009
    • 336
    I need to replace the hard drive on a Canon IR 5020. Does anyone know what drive it takes? It is far from here and I'll purchase a new drive and get it flashed. I need to know what size and style it is.
  • northernlife
    • Sep 2011
    • 847
    Re: IR 5020 Hard Drive Replacement
    FK2-9316-000 2.5 sata. The only thing is I'm pretty sure the hard drives for the 5020 are encrypted so you can't do the 2200 .ini trick to get it to use any drive. teckat would know more on this than I do though.
    • teckat
      • 16083
      iR5020
      internal 10 GB hard drive
      Canon OEM Hard Disk Drive is WM2-5222-020
      or HARD DISK DRIVE (HDS728040PLAT20)
      did u have an e602-xxxx code
      these other HDD's will also work ---
      iR5020 SUPPORTED HDD’s
      HDWN 'SAMSUNG SV2001H
      HDWN 'SAMSUNG SV0211H
      HDWN 'SAMSUNG SV0221N
      HDWN 'SAMSUNG SV0411N
      HDWN 'SAMSUNG SP0411N
      HDWN 'FUJITSU MPF3102AT
      HDWN 'FUJITSU MPC3032AT
      HDWN 'FUJITSU MPD3043AT
      HDWN 'FUJITSU MPE3064AT
      HDWN 'FUJITSU MPG3102AT E
      HDWN 'FUJITSU MHK2060AT
      HDWN 'FUJITSU MHN2300AT
      HDWN 'FUJITSU MHT2020AT MF
      HDWN 'FUJITSU MHV2040AH
      HDWN 'QUANTUM FIREBALL CX6.4A
      HDWN 'QUANTUM FIREBALLlct10 05
      HDWN 'QUANTUM FIREBALLlct08 04
      HDWN 'QUANTUM FIREBALLlct15 07
      HDWN 'QUANTUM FIREBALLlct20 10
      HDWN 'TOSHIBA MK6014MAP
      HDWN 'TOSHIBA MK6015MAP
      HDWN 'TOSHIBA MK1016GAP
      HDWN 'TOSHIBA MK6017MAP
      HDWN 'TOSHIBA MK2023GAS
      HDWN 'TOSHIBA MK4032GAX
      HDWN 'IBM-DJSA-210
      HDWN 'IBM-DJSA-205
      HDWN 'IBM-DARA-206000
      HDWN 'ST34311A
      HDWN 'ST34313A
      HDWN 'ST310211A
      HDWN 'ST340015A
      HDWN 'ST92011A
      HDWN 'IC25N006ATDA04-0
      HDWN 'IC25N010ATDA04-0
      HDWN 'IC35L040AVER07-0
      HDWN 'IC35L020AVER07-0
      HDWN 'IC25N010ATCS04-0
      HDWN 'IC25N020ATMR04-0
      HDWN 'Maxtor 2B020H1
      HDWN 'MAXTOR 4K020H1
      HDWN 'Maxtor 2F030J0
      HDWN 'Maxtor 2F040L0
      HDWN 'WDC WD300AB-00BVA0
      HDWN 'WDC WD400BB-22HEA0
      HDWN 'WDC WD400BB-22JHC0
      HDWN 'WDC WD800BB-22JHC0
      HDWN 'ExcelStor Technology J120
      HDWN 'ExcelStor Technology J640
      HDWN 'HDS722540VLAT20
      HDWN 'HDS728040PLAT20
      HDWN 'ST340014A
      HDWN 'ST940210A
      HDWN 'Hitachi HTS541640J9AT00
      • yormets
        • May 2009
        • 336
        Yes I did get that code. I tried to format it but it won't work. So it's a 2.5 SATA 10 GiG. Thanks for all the info.
        • teckat
          • 16083
          ______(:
          Like I posted_-U need an OEM part or any of the other older HD's (search Google)
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Like Teckat said, you can't just put in any old 10GB 2.5" SATA drive in and expect it to work. it MUST be on the list he so graciously provided.
