IRC2880i Dead
  • Cocha
    • Jun 2013
    • 5
    [Dead] IRC2880i Dead
    I have green power on light on control panel but machine but machine does not start up.
    I eventually found a blown fuse on the AC Driver PCB which has now been replaced and that's as far as I can go as no used to these machines
    any ideas
  • Canon.Tech
    • Mar 2009
    • 335
    Re: IRC2880i Dead
    Most likely the AC driver board is dead especially as you found a blown fuse.
    Before you replace it, It is worth removing all the cards and connections in the control box this is a common fault on this model.
    • Cocha
      • Jun 2013
      • 5
      Re: IRC2880i Dead
      Thanks for the advice, I have also seen checked canons UFO and is says to replace main controller pcb
      • northernlife
        • Sep 2011
        • 847
        Re: IRC2880i Dead
        If that doesn't work then try
        The remote signal at J254E, pin 3 on the Controller Power Supply (UN12) was only reading 1.0 volt. The remote signal should be at least 3VDC. The signal was checked back to the Low Voltage Power Supply at J302E, pin 3 and it was also low.
        In this case, the Low Voltage Power Supply was defective, thereby preventing the Boot-Up Process to initialize. The Low Voltage Power Supply was replaced to resolve this issue. The part number for the Low Voltage Power Supply is (FM2-5544-010).
        or
        This issue was caused by the DC Driver. The part number for the DC Driver is FM2-8264-000.
        All I can dig up on this issue it's been years since I've had a dead machine, knock on wood
        • Cocha
          • Jun 2013
          • 5
          Re: IRC2880i Dead
          Lol @northern life,
          Replacing board tomorrow, will update
          thanks
          • northernlife
            • Sep 2011
            • 847
            Re: IRC2880i Dead
            fix it yourself then bub
            • Cocha
              • Jun 2013
              • 5
              Re: IRC2880i Dead
              Apologies @northern life wasn't being rude the lol was your quote "haven't had a dead machine in years"
              appreciate all the help on this site as been out the game for a long time and the last canon series I looked at was GP
