Irc2550 rainbow lines
  • mrfuser
    • 1611
    Client has c2550 that prints fine bw but full color leaves a rainbow pattern along edge.
    Any ideas?
    kelly
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Irc2550 rainbow lines
    Most likely one of, or all 3 colour drums, check the drum life % in service mode, & visually inspect the drums do they look worn? also if the rainbow lines are a zigzag Patten then you may need to replace the cleaning unit as it's not cleaning the skew setup off the transfer belt.
