IR5020 Jamming
  • maxmax
    • Aug 2010
    • 12
    [Jamming] IR5020 Jamming
    Hi,
    First page is always jammed
    I open door and the paper always stays on the feeding belt like picture there is no jam code on the front board.
    Please anyone help me.
    Max
  • Brian8506
    • 1666
    Re: IR5020 Jamming
    If its every copy, check upper fuser roller drive gears. Jam code is in sm. Looks like it would be 0110. Also the transport belts ride over small black rollers on a shaft that can drift towards front or rear if plastic guide breaks. Also check lower fuser roller for binding
    • jiongpao
      • May 2009
      • 414
      Re: IR5020 Jamming
      Check the 52T gear that attached with upper fixing roller. If the gear broken the upper fixing roller doesnt rotate and that will cause the paper cannot go through it.
      • maxmax
        • Aug 2010
        • 12
        Re: IR5020 Jamming
        Thanks appreciate it.
        It was broken gear(52t) of upper fusing roller.
        I got the part today and replaced and it's working normally.
        Thanks and Happy New Year!
