ir3300- ir3045
  • akm
    • Sep 2012
    • 155
    [Error Code] ir3300- ir3045
    Dear CopyTechTeam,
    Please i want your help for the problems which i faced 1) ir 3300i finisher j the screen display error e585
    2) error 001 in ir3045 evenafter change the fixing film assy" and the dccon pcb
    thanks
    akm
  • blee
    • 51
    Re: ir3300- ir3045
    Im no help on the first problem but on #2 make sure you are going through the reset procedure for the code- Get into service mode then go to COPIER>FUNCTION>CLEAR>ERR Then reboot the machine if it doesn't do it itself.
    • northernlife
      • Sep 2011
      • 847
      Re: ir3300- ir3045
      1st 3300 e585 fiinisher j1. Delivery tray limit error, m5, s9, 10 or the finisher controller board. Does the tray try to cycle up and down when the machine is powered on? If it does, does it lock up in the up or down position? Any weird clicking/clunking noises?
      2nd 3045. First check to see that hot, neutral and ground are all ok on the clients side. If fixing e-code doesn't clear you may want to try the mains power supply. Main PS drives the AC driver. If you have a spare machine to swap parts from it could really help you out.
      • akm
        • Sep 2012
        • 155
        Re: ir3300- ir3045
        thanks eng. northernlife
        first ir 3300 yes i hear clunking noises . second i will try to change the main PS which drives the AC driver
        thanks
        akm
        • Brian8506
          • 1664
          Re: ir3300- ir3045
          On the 3300 make sure the finisher tray isn't stuck. I once had the foam around it get real sticky and impede it's movement. Somebody had spilled something. Might as well look at the obvious first.
