black bands on copies
  • aakash@24
    • May 2011
    • 41
    [CQ] black bands on copies
    iam facing this problem of black bands emerging on copies even if i change the drum.It is happening in 3 machines.I have changed the drum.pcr,hvt,drum unit.
    new drum only yields 200-300 copies.Image arttached
    changed the HDD with new firmware aslo.sometimes the drum yields more than 5k and then problem arises
  • IkeW0491
    • Oct 2013
    • 172
    Re: black bands on copies
    HI CQ,
    WHat type of machine is this?
    That info will help a great deal, thanks.
    IKE
    • northernlife
      • Sep 2011
      • 847
      SLK is 2870 I believe. Is that printout coming directly from the unit or a copy?
      • aakash@24
        • May 2011
        • 41
        Both while printing and copying.this problem is like a virus.it started in 2870 and i have 2 more machines with same problem.i am using same drum and toner on my other machines and they r wrnkg fine.
        • aakash@24
          • May 2011
          • 41
          Ir 2870
          • IkeW0491
            • Oct 2013
            • 172
            Could be an issue with the pressure roller, possibly being worn and having a wear point on it.
            This can sometimes lead to streaking like this.
            IKE
            • aakash@24
              • May 2011
              • 41
              But these are dark bands
              • Brian8506
                • 1664
                Why don't you try switching dv unit with another machine.
                • aakash@24
                  • May 2011
                  • 41
                  Swapped the dp with another machine it works there.
                  • aakash@24
                    • May 2011
                    • 41
                    The problems makes the drum unusable.changed pcr .right door transfer asssy hvt
                    • Brian8506
                      • 1664
                      Does the drum look worn when you remove it? You've replaced or swapped everything that contacts it. The only other thing I would look at would be the erase lamps or the laser although I've never heard of a laser or erase lamps damaging a drum. Check door specs for developing also.
                      • aakash@24
                        • May 2011
                        • 41
                        Some drums are scratched on sides .some r ok.
                        • northernlife
                          • Sep 2011
                          • 847
                          can speak for myself and another user on the forums but we did get a batch of bad gpr15/16 drums that caused all sorts of wonky things. It was the only time in my 11 years of being a Canon tech that Canon actually requested to have a drum unit sent back directly to tech support
                          • aakash@24
                            • May 2011
                            • 41
                            The drums i am using are working on othr my machines.i have ordered new magnet rods and spacrers lets see .
                            • sureshraidu
                              • Oct 2011
                              • 28
                              black bands
                              Use best quality drums and pcr.
                              This is a common problem in 3300/2230/2870 etc. Its only because of low quality of drum and pcr.
                              Whenever u get this problem, see there on drum and pcr carefully for spots at both ends.
                              Also u can extend your ordinary drums life by sticking one round of athesive tape ( cello tape) on the drum at both ends where spacer rollers attach to drum.
