Canon IR 2270 touch screen
  • copyman
    Owner / Technician
    • Sep 2005
    • 4667
    What is the procedure to calibrate the touch screen? Thanks in advance
    Re: Canon IR 2270 touch screen
    service mode > copier > function > panel
    TOUCHCHK Adjusting the coordinate positions on the analog touchpanel
    <Operating procedure>
    - Align the press positions on the touchpanel and the coordinate positions on the
    LCD section.
    - If the LCD section has been replaced, execute this service mode.
    1) Select TOUCHCHK to reverse itsdisplay. Then press the OK key.
    2) Press sequentially the nine positive signs (+) that appear on the touchpanel in
    order.
    • Brian8506
      • 1664
      If they're too far out of alignment replace touch panel glass FK2-0329-000
      • Hansoon
        • Sep 2007
        • 3380
        Densi has them. Their part # CATP0001
        Hans
        • HU_Canon
          • Oct 2010
          • 18
          LCD section.
          order.
          It is working if you don't have any other IDEA:
          Login User Setup mode (Star in head button)
          system settings (need Admin login sometime)
          3rd side of the menu
          Initialize All Data/Settings
          about 10-12 minutes and will be working again.
          If is works any other technician please "like" :-) this
          Just another important thing:
          DON'T use backup Data because the problem will be appear again.
          HANDJOB. :-) the user optional data setup.
          Thanks and (sorry 4 my bad English)
          • mattinhbo1803
            Replace touch screen! or check mattress touch screen
            • HU_Canon
              • Oct 2010
              • 18
              You are welcome: mattinhbo1803
              • HU_Canon
                • Oct 2010
                • 18
                Good news: Yesterday help this method again on a Canon iRC3580 Touch Screen freezing problem.
                USE IT before buy a new one!!!
                • Canuck
                  Tech Specialist
                  • 1713
                  You will be back to replace it. Known problem from Canon...new ones have glue to prevent poor contact. I have changed about 20 in the last year or two. Clean,recalibrated,re-initialize,.....do as you wish. You WILL be back to replace it. FK2-0329 is the new improved one
