I have changed the ITB cleaning blade but I still have dirt when I print out. I suspect the black drum unit which is leaking how do I go about it? pls I need help. Thanks in advance
IR3200
Re: IR3200
Can you show the picture how dirt but if you suspect with black drum > try to change it or clean the drum unit.
Good luck -
Re: IR3200
then look inside printer toward the rail where cleaning blade slides into
( note--make sure to also slide out fuser ) there is probably waste toner sitting along that rail --- it's gets messy -unless u vacuum -lay paper down inside the bottom of printer & over that secondary transfer-- u can wipe with a damp cloth to clean-
also when u have out the ITB --REMOVE the metal plates and clean them off/ u will probably see toner on them (inspect both sides )**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
