IR3200
  • sniper2g8
    • Jan 2013
    • 117
    [Misc] IR3200
    I have changed the ITB cleaning blade but I still have dirt when I print out. I suspect the black drum unit which is leaking how do I go about it? pls I need help. Thanks in advance
  • gcsbkk
    • Aug 2013
    • 22
    Re: IR3200
    The exact model is IRC3200
    Can you show the picture how dirt but if you suspect with black drum > try to change it or clean the drum unit.
    Good luck
      • 16083
      Re: IR3200
      ----------------------------- did u remove all drums + toners + ITB unit + cleaning blade
      then look inside printer toward the rail where cleaning blade slides into
      ( note--make sure to also slide out fuser ) there is probably waste toner sitting along that rail --- it's gets messy -unless u vacuum -lay paper down inside the bottom of printer & over that secondary transfer-- u can wipe with a damp cloth to clean-
      also when u have out the ITB --REMOVE the metal plates and clean them off/ u will probably see toner on them (inspect both sides )
