canon IR 2020 jaming and messge " change paper size "
  • adel_nathan
    • Jul 2011
    • 103
    [Jamming] canon IR 2020 jaming and messge " change paper size "
    hi every body
    i have canon Ir2020 jaming after seconed paper pass 20cm (A4) from finisher
    and messege " change paper size"
    i change seperation roller , and change tension spring
    and the problem dosn't solve
    any other idea
    sorry because my english is very bad
    thanks
  • adel_nathan
    • Jul 2011
    • 103
    Re: canon IR 2020 jaming and messge " change paper size "
    i try to change cassette size to (A4r) it's working good
    but (A4) jaming and give messege
    thanks
      • 16083
      Originally posted by adel_nathan
      hi every body
      any other idea
      thanks
      could be a defective Size Detection Assy. { FM2-3319-000 }
      When you open a specific drawer/cassette, you will see a knob/switch on the front left corner or right corner of the drawer. The knob/switch determines which size paper is configured for that cassette. On that knob you will see all of the paper sizes that the specific drawer can hold. You can twist this knob to the specified paper size. This selection will now appear on the LCD. To verify the Paper Selection:
      1. Press the Copy button.
      2. Press Paper Select.
      3. Now you will see what paper size each cassette is set for.
      1-Try adding an extra wrap to the spring for the Registration Sensor (SR209) flag
      check for a worn Sensor Flag (FC6-4310-000) for the Registration Sensor,
      2-check by swapping cassettes if possible ?
      3-check if u receive message from using Bypass
      • adel_nathan
        • Jul 2011
        • 103
        i check the RS209 flage , it's ok , and i warp spring
        but not solve the problem
        please , any more good idea , will help
        thanks
        • bineeshgeorge
          • Jul 2009
          • 107
          hi every body
          any other idea
          thanks
          Check the registration clutch or remove the black bush attached with separation roller.
          • adel_nathan
            • Jul 2011
            • 103
            where the black bush ???????
            i checked registration clutch , it's look like good
            thanks
              • 16083
              thanks
              read this two pdf's------------------
              Prevention of Incorrect Paper Size Error
              for your model
              • northernlife
                • Sep 2011
                • 847
                you cannot detect a bad board or component simply by looking at it. Like teck said, size detection PCB is the usual cause for this problem. If you could supply us with a jam code that would help tremendously
                • adel_nathan
                  • Jul 2011
                  • 103
                  thank you all
                  the problem is solved
                  the solonid arm was sticked and causing withdraw more than one paper each time
                  so the machine feeling the paper is not A4 size
                  thanks for help
                  • mramlawi
                    • Jul 2011
                    • 838
                    change all the feed assembly with a new one your problem will solve ,it happened so much with me and i tried also to replace the 2 gears befor and it still the same problem so i changed the new feed Assembly and it work
                    Distinguished road makes you jewel in rough
