Canon ir3235 not fusing on heavy paper
  • kuby
    • Oct 2007
    • 1409
    Have a funeral home that runs some 5 1/2 x 8 1/2 cards from the cassette. Have the temperature set as high as it will go and the fusing is not that great (duplex). It pulls some on the toner off the page. If you run it thru the bypass it is OK because you can tell it you are using heavy paper then you have to run the other side, is there a setting some way to the machine you are using a heavy paper from the cassette? Or at least slow the machine down when using the heavy paper from the cassette?
  • its_just_a_copier
    • May 2011
    • 132
    Re: Canon ir3235 not fusing on heavy paper
    Most likely you are running the machine out of spec.
    • northernlife
      • Sep 2011
      • 847
      common settings, set paper type. I don't have a unit in front of me if it's on the machine that's where it'll be
      • Canuck
        Tech Specialist
        • 1713
        Max paper weight on this model is 128 gsm2.....
        • teckat
          • 16083
          Acceptable Paper Weight
          17lb. Bond -20 lb Bond (Drawers)
          Plain and Recycled paper are from 17 to 24 lb bond (64 to 90 g/m2)
          Load paper heavier than 20 lb bond (81 g/m2) in the stack bypass.
          17lb. Bond -32 lb Index (Stack Bypass) Heavy paper is from 24 to 32 lb bond (91 to 128 g/m2)
          no heavy setting for drawers
          • Brian8506
            • 1665
            It is in common settings under store paper type. Not sure how many options it gives you.
