irc3480 turn off auto recieve
  • Jerrygbs
    • Dec 2008
    • 194
    Can auto receive be turned off? I cant find it anywhere.
    • 16083
    Re: irc3480 turn off auto recieve
    set the fax ring count to prohibit auto fax reception
    Facsimile modems are generally expected to auto-answer after two rings.
    If the modem answers within thirty seconds (approximately 4.5 rings), auto-reception should occur.
    You can effectively disable auto reception by setting the ring count to a value much higher than 4 (for example, 25; max. 99).
    No sending unit is generally programmed to wait this long. Also, some phone systems will not allow you to wait on-line that long without generating a warning message. To set the number of rings see the following:
    For fax-enabled imageRunners
    -Enter Service Mode on the device then select Fax to enter the Fax Service Mode.
    For stand-alone fax units
    -Enter the Fax Service Mode.
    Service Modes for various models
    RX
    • Jerrygbs
      • Dec 2008
      • 194
      Teckat you were a life saver as usual thanks
        • 16083
