np6512
  • akm
    • Sep 2012
    • 155
    [Misc] np6512
    Dear/ CopyTechTeam,
    First of all Happy New Year then i faced aproblem with np6512 gives a white copy what can i do to solve this problem
    thanks
    akm
  • Blizzoo
    • Aug 2013
    • 610
    Re: np6512
    Check the Drum Drive if isn't stuck,clean and inspect the charging terminals located on rear back of the machine,most likely there is a problem.
    For a better troubleshooting,make an hard stop in a copying process and inspect Drum if there is toner deposited
    • teckat
      • 16083
      Re: np6512
      Originally posted by akm
      Dear/ CopyTechTeam,
      thanks
      akm
      -Is toner inside the toner cartridge?
      -Has the open seal been removed?
      -Does the drum drive gear rotate normally? (Be sure to install the drum unit before making checks)
      -Is the primary charging terminal on the front left of the drum unit in firm contact with the high-voltage terminal at the machine's bottom?
      1. Check the contacts for electrical continuity.
      2. Replace the drum unit.
      • JustManuals
        • Jan 2006
        • 9838
        Re: np6512
        http://www.justmanuals.com/canon-copier-np-65126612712071307130f-parts-service-manualpdf-p-22127.html
        Paul@justmanuals.com
          • 23010
          Re: np6512
          Check that the developer shift spring rear is still attached to the post on the rear frame. Most likely the post will be broken off. =^..^=
          • Brian8506
            • 1666
            Re: np6512
            Assuming this model is like the 6012, this will probably hit it right on the head. If you open the clamshell and look from underneath you may see dv unit out of position. I usually remove the boards in the back and drive a strong tapping screw into the hole where the mount broke. It will be much stronger than the original mount.
              • 23010
              Re: np6512
              Originally posted by Brian8506
              Assuming this model is like the 6012 ...
              Yes that's correct. =^..^=
