canon ir5000/6000
  • micann143
    • 25
    canon ir5000/6000
    hello everybody i have canon ir5000dn i want to format the hdd.120gb.it is possible to use the SST? it is a new one HDD
    and how?can you help me please!!!!!!
    thank you so much in advance and happy new year god bless you all..!
  • copyman
    Owner / Technician
    • Sep 2005
    • 4646
    Re: canon ir5000/6000
    If it is like other Canon's you will need to install system software with new HDD. You can use the SST to format & install system software.
    • teckat
      • 16083
      U can use only a Canon OEM HDD for this model ==WM2-5137-000
      or below
      HDWN 'FUJITSU MPC3032AT
      HDWN 'FUJITSU MPD3043AT
      HDWN 'FUJITSU MPE3064AT
      HDWN 'FUJITSU MPF3102AT
      HDWN 'FUJITSU MHK2060AT
      HDWN 'FUJITSU MPG3102AT E
      HDWN 'FUJITSU MHN2300AT
      HDWN 'FUJITSU MHT2020AT MF
      HDWN 'FUJITSU MHV2040AH
      HDWN 'QUANTUM FIREBALL CX6.4A
      HDWN 'QUANTUM FIREBALLlct10 05
      HDWN 'QUANTUM FIREBALLlct08 04
      HDWN 'QUANTUM FIREBALLlct15 07
      HDWN 'QUANTUM FIREBALLlct20 10
      HDWN 'TOSHIBA MK6014MAP
      HDWN 'TOSHIBA MK6015MAP
      HDWN 'TOSHIBA MK1016GAP
      HDWN 'TOSHIBA MK6017MAP
      HDWN 'TOSHIBA MK2023GAS
      HDWN 'TOSHIBA MK4032GAX
      HDWN 'IBM-DJSA-205
      HDWN 'IBM-DARA-206000
      HDWN 'IBM-DJSA-210
      HDWN 'ST34311A
      HDWN 'ST34313A
      HDWN 'ST310211A
      HDWN 'ST340015A
      HDWN 'ST92011A
      HDWN 'ST340014A
      HDWN 'ST940210A
      HDWN 'IC25N006ATDA04-0
      HDWN 'IC25N010ATDA04-0
      HDWN 'IC35L040AVER07-0
      HDWN 'IC35L020AVER07-0
      HDWN 'IC25N010ATCS04-0
      HDWN 'IC25N020ATMR04-0
      HDWN 'Maxtor 2B020H1
      HDWN 'MAXTOR 4K020H1
      HDWN 'Maxtor 2F030J0
      HDWN 'Maxtor 2F040L0
      HDWN 'WDC WD400BB-22HEA0
      HDWN 'WDC WD400BB-22JHC0
      HDWN 'WDC WD300AB-00BVA0
      HDWN 'WDC WD800BB-22JHC0
      HDWN 'HDS722540VLAT20
      HDWN 'HDS728040PLAT20
      HDWN 'SAMSUNG SV2001H
      HDWN 'SAMSUNG SV0211H
      HDWN 'SAMSUNG SV0221N
      HDWN 'SAMSUNG SV0411N
      HDWN 'SAMSUNG SP0411N
      HDWN 'ExcelStor Technology J120
      HDWN 'ExcelStor Technology J64
      HDWN 'Hitachi HTS541640J9AT00
      • micann143
        • 25
        sir.. can you give me an simple idea how to format using SST?thank you..it is possible to connect using direct the cable from machine to laptop ?
        or there's need the internet connection?
        • teckat
          • 16083
          why don't you call for a trained tech
          HDD must be in printer to Format it
          1-u need the iR5000 FIRMWARE downloaded into laptop/pc
          2-u then need to register the FIRMWARE into SST
          3-u need the correct cable from laptop/pc to printer
          when all that is complete> u can then start the format process using SST & the 5000 models Format file
          • songela
            • Mar 2008
            • 216
            I suppose that you got the SST along with its manual, you better read it to gain confidence. Also read the UPGRADING chapter of the IR5000/6000 Service Manual.
