IRADV C5030 Insert Black Drum Unit
  • RHodg57
    • Dec 2013
    • 191
    [Misc] IRADV C5030 Insert Black Drum Unit
    Copier is giving this message. Haven't seen this before on this model.
    It appears the black developer is not turning even though the linkage
    that breaks is okay. Going to try a motor test and see what happens.
    It is a machine we received used and is for our shop use.
    Has anyone seen this?
  • northernlife
    • Sep 2011
    • 847
    Re: IRADV C5030 Insert Black Drum Unit
    Only thing I can find in casefiles is a blow dc-con.
    • Canuck
      Tech Specialist
      • 1713
      Machine detects drum presence by measuring primary charging current i believe. Did you try another drum unit?
        • 16083
        Remove & Re-seat the drum
        Re-seat drum process kit assembly
        Re-seat ITB unit
        • RHodg57
          • Dec 2013
          • 191
          Tried all of the above including the DC Controller and no luck.
          Thanks for the suggestions!! We will continue to try things.
          • Tonersniffer
            • Nov 2012
            • 74
            I hope you got it running.
            I had noise issue and thought the linkage was fine also. Ended up ordering the drive unit. The one I ordered didn't come with the 4 motors. Wasn't too badly priced either. But it wasnt easy to replace. But the never called back. After pulling the unit it was obvious the problem (plastic bearings were worn out) . not sure it the same issue is yours but if you are not getting black drive it could be.
            • RHodg57
              • Dec 2013
              • 191
              We got in a machine that works and attempted some part swapping with no success. We tried HVT2 that charges the primary ac and detects the voltage
              from the primary. That is how this machine detects the presence of the black drum unit. We tried power supplies and relay pcb and main controller
              1 still no luck. We did swap out process units and ITB assembly, no luck with that either. Guess it could be a wiring problem. Any other thoughts?
              The black drum does rotate.
              • THUK
                • 195
                Hi i had this prob with Cyan and it was the HVT PCB on the left side of copier,we tried Dc Con first and that did not cure it.
                • RHodg57
                  • Dec 2013
                  • 191
                  I replace the Imaging H.V.C. Assembly. Part Number FM3-6076-010.
                  Inexpensive part but a lot of work to get to it as it mounts on the black
                  toner hopper.
                  Now the machine runs but I get no Cyan. I checked the coupling on the developer
                  as we have had those break in the past but it is okay.
                  Checking wiring now.
                  • RHodg57
                    • Dec 2013
                    • 191
                    Got all the colors now. When I had the laser unit out I didn't get one connector plugged back in on reinstall.
                    That's what I get for hurrying.
