How I Change pressure pad ass"y FM#-1217-000
Re: How I Change pressure pad ass"y FM#-1217-000
Paul@justmanuals.comComment
This is part of your lower Fixing Belt Assy. If you are going to change this, yes you should have the Service Manual handy because you have to dig into the Fixing Assy to do it. Too many steps to list here.
I've changed this part problably a few hundred times. I would recommend you also replace the nearby parts as a set:
Pressure Pad FM3-1217-000 Pressure Pad Cover FL2-2788-010 Oil Roller FL2-5453-000 Lower Fixing Belt FL2-6530-000 Steering Roller FC5-9766-000 Comment
