IR 3200 Image Quality Problem
  • Codex
    • May 2008
    • 704
    Hello
    I have a Problem with a Canon IR 3200,if i make a normal copy or a Print the copy/print is ok, but if i make a copy/print of a document with big letters or a Photo in it the quality is not so good, the letters are light /blured inside and not really black, but a kind of grey.
    I tried to change the Drum Unit and the Development Unit and also the Transfer Unit but the result is the same........
    Thank you
    Memento Audere Semper
  • kwazimoto
    • Jan 2007
    • 199
    the drum unit and the dv unit are the one and the same... if printing is ok then the problem sounds like it is to do with the scanner ..because you prints are k.. have you did a auto gridation... to see if that changes anything... also is it just black that is bad or all colors????
    • Codex
      • May 2008
      • 704
      Hello
      I tried to change the Drum UNit, but with no result.....It's a B/W Printer, it's not an IRC but only IR....the problem is only on Black.I also changed the Toner supply unit....but same problem
      • peterepeat
        • 84
        The Canon IR3200 is a color machine. Is it an IR3300 maybe?
        • yourownfree
          • Dec 2007
          • 474
          sounds like peterrepeat might be right, not a color machine. Sounds like somebody tried to save money and not put the right toner in the machine.
          • _SuabE_
            • Jan 2008
            • 108
            How many copies the machine does now? Did you ever clean the laser unit?
            sigpic
            Senior Technician Specialist
            A+; Network+
            Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
            Printer Handled: Canon, HP, Epson, Brother, Samsung
            Duplicators: Risograph, Duplo
            • Codex
              • May 2008
              • 704
              Hello
              The Toner are new, and i cleaned the LAser Unit last week, but the maschine have still the same problem.
              Thank you all for your Help
              • toddbac
                Stop the image under the drum and see if the image is good there. It should be good there because I believe that the problem lies in the fuser unit. Change the fuser film.
                Todd
                • Codex
                  • May 2008
                  • 704
                  Hello
                  The fusing unit is new..........
                  • bicool
                    • 49
                    Try to increase and reduce darkness from the first screen to see any change, if no, go to ADJUST in service mode and check the value for DENS....
                    • pspahr
                      Toner Schlep
                      • May 2008
                      • 227
                      Keep It Simple S.....
                      Have you checked to see what the default original settings are? Is it set default to text, photo, text/photo?
                      Not real familiar with the Canons just yet but the problem you describe is dead on with a Ricoh set to text/photo or photo mode. The machine is sharpening the images by giving more grayscale gradation and doesn't handle text very well when doing this.
                      Just a thought
                      VectorLinux---Check it out!
                      • yourownfree
                        • Dec 2007
                        • 474
                        after replacing the drum you need to go to functions in service mode and run DGamma. then go through the ccd adjustments that the service manual says to do. ccd adjust, shading etc. check the door specs and see if your machine is set to door specs first. (default specs) check your transfer to see if you see anything there, transfer roller etc. that needs help. dev assy too.
                        • Codex
                          • May 2008
                          • 704
                          Thank's to all, i will try this weekend to fix it...
