Canon IR C3200 on a network
  • JDP9164
    Hi I am trying to configure a Canon IR C3200 on the network and unfortunately I do not find any menu proposing this network settup (IP @, mask,...) This printer has already worked on this same network but the C1 (Fiery) server has been exchanged due to a failure and then I try to make it run...
    any suggestion would be appreciate. How to get in this set up menu, in which order power on the printer or the C1 server,...
    JD
  • printerguy77
    • Feb 2014
    • 26
    Re: Canon IR C3200 on a network
    You more than likely have to reload system software and patches to the C 1 if you can't see it. Also make sure you have ing-cnt set to 3 in service mode.
    • JDP9164
      Thank you for answering my trouble. I suspected that. Nom I try to find out this software to manage th C1 (Fiery system software Installer...) which seems not easy to find.
      ing-cnt is set to 3
