ImagePass-C1 X3e-01
  • jfb
    • Jun 2025
    [Dead] ImagePass-C1 X3e-01
    I'm no tech but able to manage so far with all my computers and printers. We have a used CANON C3220 with a ImagePass-C1 X3e-01 that is not longer communicating with anyone (computer and printer). The network card on the Imagepass show the 2 led and 1X flashing but I'm not able to enter communication. Same thing with the printer. I know I didn't turn it of the right way a few time. Hardware problem ??
  • KL568
    _
    • Feb 2011
    • 324
    Re: ImagePass-C1 X3e-01
    Hi,
    Are you pretty sure this rip used to work on this iRC3220?
    I had tried once and after a long wait it throw out a error code. Took out the rip and plug it to iRC3200, it bootup like a charm. My iRC3220 firmware was at it latest and Rip firmware version is 2.1.2
    • jfb
      Originally posted by KL568
      Hi,
      Many thanks to answer me...
      Yes i'm sure. I just buy it 2 weeks ago. It was working fine at the beginning but went i started to do change in the menu, i lost communication with the ImagePass-C1. The printer keep saying to check network connection. And i'm not able anymore to go in the printer status setting. Keep saying to check printer server cable. I'm shure about one thing. the hard disk is almost dead.
      • charm5496
        • 2387
        these devices are old and if your HDD is toast then you need to replace and load new firmware on it.
        You can take a chance and buy a used HDD with the firmware on it, but you might end up in the same situation you are in right now
        • jfb
          That is exactly what i think. Even replacing the IMAGEPASS is a solution. But does it worth-it!
          THANKS
