canon 4080i smudging
  • kuby
    • Oct 2007
    • 1410
    Have a 4080i that is smudging on the page. Needed new black drum and magenta drum and I figured that would take care of it. Smudging still there. Cleaned the transfer unit, still there. Fusing unit looks OK about 80,000 on it. Any suggestions would be appreciated.
  • copier tech
    • 8193
    Re: canon 4080i smudging
    Very common fault on this model & the previous CLC3200 series.
    Remove & clean the ITB belt, particularly the metal plate that sits on the underside, toner builds up on this plate (from the leaking black drum unit) & causes the exact issue you have.
    • SAZ911
      • Mar 2013
      • 193
      hi,
      I agree with Copier Tech, very common problem, thorough clean of the ITB assy should do the trick......
      SAZ911..........
      • Canuck
        Tech Specialist
        • 1713
        There is a modified plate for this...plate hangs down away from belt....installed many in the past
