Canon IR5055 warmup and coming to ready problem
  • essgee
    • 10
    [Misc] Canon IR5055 warmup and coming to ready problem
    The copier comes to ready, but when you press the copy start button it flashes feeding paper, then it goes back into warming up, and the display reads printer warming up. This continues to cycle until you delete the copy or print job, etc. I've changed all the Thermistors.
    Thanks for your help,
    Steve
  • northernlife
    • Sep 2011
    • 847
    Re: Canon IR5055 warmup and coming to ready problem
    WHen you close the fixing/feeding tray it makes contact with two spring loaded black connectors. They may be damaged. What's copier > Display > Analog say when you're having this issue, should control rotation at 190 and start feeding at 198
    • ernesto
      • Oct 2011
      • 430
      hi
      can you print something for example pd print?
      • northernlife
        • Sep 2011
        • 847
        highly highly doubt it. What's analog say??
        • JustManuals
          • Jan 2006
          • 9838
          • essgee
            • 10
            Analog initially comes to ready 190-198, then fluctuates down to 140-145.
            • essgee
              • 10
              Originally posted by ernesto
              hi
              Haven't tried, but will.
              • essgee
                • 10
                Analog comes to 190-198, then will fluctuate down to 140-145.
                • tinnyjay
                  • Oct 2009
                  • 666
                  Steve
                  Are you using a finisher with stapler?
                  If yes,try to remove staples.
                  "Who loves the roses,must also bear thumbs"
