Canon IR105 plus Background on print and copy.This happened only after adjusted magnet positioning plate in Dev. unit. How can I rectify this problem.If anybody have an idea pl. share it me.
IR105+ machine background on print and copy
Re: IR105+ machine background on print and copy
But what i understand is that you have removed mag roller blade(doctor blade).
The distance between magnetic roller and its blade is higher than it should be,therefore you have a blurred background.
So you have to decrease this distance to have a good image.
Put a paper 80 gsm between mag roller and blade and let the blade go freely to the mag roller.Put the fixing the srews and remove easily the paper.
Thats it."Who loves the roses,must also bear thumbs"
