Drum Pinholes issue in IR105 machine
  • tomson25
    • 104
    [CQ] Drum Pinholes issue in IR105 machine
    Drum pinholes problem in IR105, Replaced Primary corona unit , Development unit and drum but same problem. pl. check the attached image.If anybody have an idea pl. share it me.
  • MjarbarV2.0
    Adeptus Mechanicus Magos
    • Feb 2014
    • 68
    Re: Drum Pinholes issue in IR105 machine
    It looks as though you have already changed the usual things for the image formation, but as you are still getting the problem have you checked the fuser roller for dinks and improper cleaning, just a thought???
    The impossible is easy - miracles take a little longer
    Let us not talk falsely now, the hour is getting late.
    • tomson25
      • 104
      I replaced the drum it works for 100,000 copies well after again pinholes.
      • Jhonjon
        • Sep 2013
        • 208
        When you replace the drum and main charge its better you also replace the transfer unit and clean the pre transfer unit or cut the corona wire. Pinholes in drum is cause by arcking.
        • CT Copier Repair
          • Mar 2010
          • 304
          Arcing for a corona
          I would restring all of them looking very carefully at everything
          Clean all the blocks check drum area for anything in it
          Make sure developer spacers are good
          Brian
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5017
            Corona is too close to the drum. Fix or replace.
            • tomson25
              • 104
              quality of corona wire cause the arcing?. I am using compatible corona wire. Is it necessary to use original corona wire from canon.
