Canon IR ADC C2020 E000025-0330
  • northernlife
    • Sep 2011
    • 847
    #16
    Re: Canon IR ADC C2020 E000025-0330
    no but I highly doubt that would give you anything other than an e020. You can check for continuity on that pin with a multimeter
    • bernardo749
      • 42
      #17
      northernlife, The pin you comment me is the one in red?74019343-IR-ADV-2020_01.jpg
      • northernlife
        • Sep 2011
        • 847
        #18
        Drum unit relay pcb BK PJ J4020 connects to J25 on the dc controller. This will not fix your e025.
        • bernardo749
          • 42
          #19
          I understand, so what's the pin I should change?
          • northernlife
            • Sep 2011
            • 847
            #20
            read through everything I posted. Toner feed motor, if not cable is shorted, if not dcon
            • bernardo749
              • 42
              #21
              I put the old toner feed assembly again and the problem persists. I wonder what the pin, because you say you've fixed the problem was to replace the blue 15 pin intermediate connector VS1-8412-015 this was found by using a meter and the Checker Board PCB FY9-4050-000 to isolate the shorted connector. Sorry I do not speak very good English.
              • northernlife
                • Sep 2011
                • 847
                #22
                M12 Toner Supply Motor (Bk) Toner Buffer Unit FM3-8084
                M13 Toner Container Motor (Bk)Toner Buffer Unit FM3-8084
                e025-0330 is an error in the toner container motor. Have you replaced the supply motor or the toner container motor? Both are the same motor so you can swap to see if it'll get your toner bottle turning
                • bernardo749
                  • 42
                  #23
                  That pin you mention this in toner feed asemmbly (FM3-8084-010)? I replace the toner feed asembly completly... Now the old and new have a short-cort! :-O
                  • northernlife
                    • Sep 2011
                    • 847
                    #24
                    aha, now I know teckat's name :-) I've only changed one of them and don't remember if there's two motor's on that assembly? I really wish I had one in shop to rip apart and help you better
                    • bernardo749
                      • 42
                      #25
                      Yes, there are two motor's ... and then I do? Install the old and also gives me the same error!
                      • northernlife
                        • Sep 2011
                        • 847
                        #26
                        so then it's the wiring harness or dcon
                        • bernardo749
                          • 42
                          #27
                          Where is located the DCON? What is your part number?
                          • bernardo749
                            • 42
                            #28
                            How could prove that these connectors are working?
                            • northernlife
                              • Sep 2011
                              • 847
                              #29
                              continuity pin to pin with a multimeter.
                              • bernardo749
                                • 42
                                #30
                                In the end I had to send to an authorized Canon photocopier in the capital center of the country. I hope for your repair.
