IR 6570
  • Rakesh Khambholja
    • Sep 2013
    • 17
    IR 6570
    I have IR6570. Almost taken out 25 lacs prints. The problem i facing is MCB of main line gets trip when i switch on the machine. If i switch on the machine with unit 1 not inserted the machine mcb is not trip. The moment i insert unit 1 and move the handle of unit one the MCB of main line gets trip. Any feedback?
  • Brian8506
    • 1665
    Re: IR 6570
    I'd be taking out the fixing feeder frame assembly and looking for a pinched fuser wire to start with. Have you done anything yet?
    • Rakesh Khambholja
      • Sep 2013
      • 17
      Re: IR 6570
      hi
      • Rakesh Khambholja
        • Sep 2013
        • 17
        Re: IR 6570
        Yes i have check unit 1 with other machines it works ok.
        • songela
          • Mar 2008
          • 216
          Re: IR 6570
          Why can't you check the Circuit Breaker as well? it may develop oversensitivity or some malfunction.
          • JustManuals
            • Jan 2006
            • 9838
            Re: IR 6570
