Anyone had repeated problems with fusers for Canon IR3570 - specifically torn sleeves?
CANON IR3570 - fuser issues?
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!". -
Someone may have messed with the pressure adjusting screws-causing the sleeve to "walk" toward one end and tearing.
I've had no luck trying to readjust them in the field, but have had to replace the entire fusing unit.
Nationwide is rebuilding these fusers now, you might want to give them a call.
