Canon irc2380
  • steve schofield
    • May 2010
    • 117
    Canon irc2380
    Hi all...I have strange problem with irc2380 it's folding paper almost in half before or at registration...no jams ...I know it before transfer can tell by image ...I have change reg clutch...I can stand at customers for a hour doing copies and prints with no problem a day or so later comes out again ...anyone had this??
  • vamoursly
    • Sep 2011
    • 273
    Re: Canon irc2380
    Hello
    Are you saying for example that the paper is getting picked up at tray 1 and before transfer / fusing the paper is being folded? Bit confusing, that would cause a jam?
    V
    • steve schofield
      • May 2010
      • 117
      Re: Canon irc2380
      Hi ...the paper is folded before fuser
      • vamoursly
        • Sep 2011
        • 273
        Re: Canon irc2380
        Getting folded on all trays and duplex?
        V
        • steve schofield
          • May 2010
          • 117
          Re: Canon irc2380
          Only seen sample from top a4 tray ..single sided only i have swopped pick up assembly
            • 23002
            Re: Canon irc2380
            Perhaps the loop adjustment is mis-adjusted? Loop adjustment is the timing of the paper between the pickup, and the vertical path to create a buckle that will correct skew for slight variations in paper feed. Too little loop is a delay jam. Too much loop is a Z-fold.
            Open your manual and find the loop adjustment. =^..^=
            • steve schofield
              • May 2010
              • 117
              Re: Canon irc2380
              Will do thanks for replys
              • steve schofield
                • May 2010
                • 117
                Re: Canon irc2380
                Hi all...turned out to be sticky damper on rear of registration flag arm....thanks for your help
