Re: Copy & Print Icon Missing on display IR 4245i
Teckat thank you very much for your continuous support
I think i was not able to explain the problem,actually in the process of firmware update the power tripped down at the customer's location,
and after restarting the Machine now i can go to copy screen,touch screen is also working fine,i can select options in copy screen IMG_20140326_182532.jpgbut it will not do anything beyond that.
and it will also not go to
→ [Function Settings.
IMG_20140326_182558.jpgthis is the firmware screen with an error .
Is there anything we can do to make it work?and i don't have the firmware to install via SST,i was trying to install it via delivery server
Regards
Regards
