B&W Prints Click as Color? iRC3220 w/ ImagePass C1
  • phorts
    Guy
    • Sep 2007
    • 59
    Hey folks,
    Got an iRC3220 w/ an ImagePass C1 attached. We have Department ID Management configured for several users. Latest Print Drivers are setup directly from each PC (Not shared) and I have their default color mode set to B&W. Each ID is allowed to print color, but we're trying to set it up so that the user must physically switch the color mode each time.
    What's happening is that the user will print something that has color, and it's printing in color and counting as a color copy. Problem is it should be in B&W, as per the default color mode. The prints should be coming out B&W and not clicking as color.
    Any ideas?
  • lkrsardis
    • Dec 2007
    • 316
    ir3220
    You have mail.
    Like the United States Postal Service It's a miracle it works!
    • phorts
      Guy
      • Sep 2007
      • 59
      You are the man!
      Thank you!
      Testing now...
      • tech_dept
        having same issue, could either of you please post this fix. thank you
        • phorts
          Guy
          • Sep 2007
          • 59
          The resolution I received did not work. Still looking for an answer to this myself. Please post if you find something that works.
          thank you!
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            If this is from a Microshaft application then that is the issue. There is a bulletin on Microshafts website about this. It seems that some of the imbedded black images are being treated as a "greyscale" color documents. Also I would take the department id code out of the driver so it prompts for it if the selection is incorrect.
            • tech_dept
              From a Canon rep, this fix has worked for us so far:
              I was able to duplicate the issue in the lab. I found out that the problem was occurring because there is a setting in tha page setup properties within Access that overrides the print driver settings. The way to correct this is as follows.
              1. Open the document that is failng to print in Black and White.
              2. Click on Print and select Print Preview.
              3. Click on the Page Setup icon on the Access toolbar.
              4. Click on Page tab
              5. Select Use Specific Printer option.
              6. Click on Printer button
              7. Choose the C3200-C1 printer
              8. Go to properties.
              9. Choose Quality tab.
              10. From Color mode select Black and White
              12. Click on ok until you exit.
              13. Now print document.
              14. Close out document ad close Microsoft Access and reopen then try to print. It should default to Black and White.
