Canon ir1024 image unit remanufacturing problem
  • nemonavicusrino
    • Feb 2010
    • 14
    Re: Canon ir1024 image unit remanufacturing problem
    Originally posted by Blizzoo
    If the I.U runs without that gear take of like you simulated after a while the waste toner will appear on the page because it's not mixed up corectly into the waste chamber.
    Salutari din Romania
    <MULTUMESC>
    THANK YOU.
    That's exactly answer what i ask for. Anyway i discovered here from other poster some very interesting information. Thaks anybody posted, for all your help.
    Sorin
    • 5ercar
      • Aug 2012
      • 10
      problem
      Hello few months ago katun had bad gears. Do you have black or white gear on opc? white is ok, black cause a lots of problems. Lp,peter
      • nemonavicusrino
        • Feb 2010
        • 14
        Re: problem
        Mine is black. but i replaced only drum and blade (compatible). imaging unit is original, after 30k copies.
        Maybe this was problem (gear forom drum). Anyway the copier seem to be fine for moment. Already have done 3000 copies withowt gear for agitator.
        Thanks for info posted.
