Image Press C6010
  • Ramanan
    • Sep 2012
    • 9
    [CQ] Image Press C6010
    Hi All,
    we are facing Color quality issue in ImagePress C6010 Printer. we just installed the printer 2 months back. Now iam getting wrong colors on outputs.
    Instead of red color we get dark pink color.
    we did shading correction / Auto correction and RIP calibration too. no improvement.
    Kindly share if anyone faced such kind of issues.
  • DANIELCANON
    • Jun 2011
    • 187
    Re: Image Press C6010
    podria ser necesario reemplazar los reveladores (starter).ejecute una prueba de impresion tipo 10. para ver si estan bien .
    • teckat
      • 16083
      Originally posted by Ramanan
      Hi All,
      check your
      M Developer Assembly-is developer) missing from developing assembly
      Drum,
      Primary Charger Assembly,
      Check the ITB assembly and the Primary Transfer Rollers and Secondary Transfer Roller.
      The Original Door Label and P-Print values/ compare all signals (P-SGNL-M, P-SGNL-Y, P-SGNL-C, P-SGNL-K)
      P-SGNL is in Service Mode Level 1 under COPIER > ADJUST > DENS.
      Input values and perform an "INIT-4" and a full auto gradation.
      • khattab.al.masry
        • 212
        Dear teckat:
        (P-SGNL-M, P-SGNL-Y, P-SGNL-C, P-SGNL-K)------where these readings are located in service mode label we checked service label readings rear main engine and front sub-engine we did not find it
        • teckat
          • 16083
          Originally posted by khattab.al.masry
          Dear teckat:
          (P-SGNL-M, P-SGNL-Y, P-SGNL-C, P-SGNL-K)------where these readings are located in service mode label we checked service label readings rear main engine and front sub-engine we did n find it
          P-SGNL values should be listed on Label
          P-Print values should show on print out
          disregard the Service Manual information for the P-SGNL as it states that this service mode is not used.
          #1 = DC Con door label from the back of the Main Engine
          • khattab.al.masry
            • 212
            Mr teckat:
            I attached photo for service label as I can not find p-sgnl that is unavailable to see it.
            Sent from my SM-J700H using Tapatalk
            • teckat
              • 16083
