Using F4 Ledger paper
  • jiongpao
    • May 2009
    • 413
    Hi.
    Can we print using F4 ledger paper 209mm x 328mm in IR7086? Please correct me if im wrong on that paper size name. Today i try on adjusting the cassette tray and theres is no F4 size indicator and it show U3 size on screen for cassette 3. When i try to copy the image shift down for about an inch. I did search on history but none of them for IR7086.
    Can someone please help me?
  • elamurugu
    • Mar 2014
    • 27
    Re: Using F4 Ledger paper
    Go to service mode -option-cassete -1to8 cheak .
      • 23009
      The closest standard size that I can find is Foolscap Folio: 210mm x 330mm. If you can find a setting for that, It probably will not jam with the 2mm difference in length. =^..^=
      • jiongpao
        • May 2009
        • 413
        Sorry brother, i dont get what you mean
        • jiongpao
          • May 2009
          • 413
          Im new with the foolscap thing and i cant believe im dealing with it. the measurement that i gave probably not very accurate since i measured using ruler hehe.
          • spectraindo
            • May 2008
            • 313
            Go to Service Mode Level 2 > COPIER > OPTION > BODY > ORG-LGL enter 1 OK.
            Still level 2 > COPIER > OPTION > CST > U1-NAME~U4-NAME enter 1 OK.
            Turn OFF and back ON the machine.
            • jiongpao
              • May 2009
              • 413
              Forgive me, how to go level 2 inside the service mode?
              • spectraindo
                • May 2008
                • 313
                Press * 28 * then * 2 . Got it ?
                • jiongpao
                  • May 2009
                  • 413
                  yes i got it, thank you.
                  Now the screen show LGL on cassette 3. Using copy glass is fine but using ADF it will shrink downward for about an inch.
                  • spectraindo
                    • May 2008
                    • 313
                    Are the paper guides in position besides the paper ?
                    If yes then you must do Cassette Sensor Adjustment :
                    Go to Service Mode level 1 for cassette no. 3 :
                    Put STMTR paper in cassette no. 3 and slide the guides to that position.
                    COPIER > FUNCTION > CST > C3-STMTR > OK
                    Put A4R paper in cassette no. 3 and slide the guides to that position.
                    COPIER > FUNCTION > CST > C3-A4R > OK.
                    Check the display should read FLSC for F4 paper.
                    And do not forget Service Mode level 2:
                    COPIER > OPTION > BODY > ORG-LGL = 1 > OK.
                    • jiongpao
                      • May 2009
                      • 413
                      Yes Spectraindo. The paper guide is in position
                      LEVEL 2 - COPIER > OPTION > BODY > ORG-LGL = 1 > OK
                      Screen show FLSC
                      But the print out result still the same as attachment above.
                      • jiongpao
                        • May 2009
                        • 413
                        I found out that if the ADF paper guide adjust to A4R /A5 (see attachment below) then the result will shrink down for an inch
                        But when the paper guide on ADF adjust to LGL / STMT /LTRR (see attachment below) the result is fine but the paper will not fit correctly on document tray.
                        • spectraindo
                          • May 2008
                          • 313
                          You can check the paper size detected by the feeder :
                          *-28-* > FEEDER > DISPLAY > FEEDSIZE = should be FLSC.
                          Check also TRY-WIDE > move the paper guide to A4 = 2970, move to A4R = 2100.
                          If not, move the guide to A4, press FUNCTION > SENS-INT, THEN TRY-A4 > OK
                          Move the guide to A5R, press FUNCTION > TRY-A5R > OK.
                          When your paper width = 210 mm (A4R) , move the guide to 215 (LGL/LTRR position) this can also be the problem.
                          Check again FEEDSIZE = FLSC.
                          • jiongpao
                            • May 2009
                            • 413
                            Both reading are fine for A4 = 2970 and A4R = 2100. But the FEEDSIZE remain at A4R. It still shrink down an inch
                            When the paper guide on ADF adjust to LGL / STMT /LTRR, the FEEDSIZE show FLSC.
                            • spectraindo
                              • May 2008
                              • 313
                              Try this, if it does not work you better slide the guides to LGL/LTRR.
                              Goto Service Mode Level 2 > BODY > OPTION > CST > CST-U3
                              Use it to specify the name of paper in a paper size group (U3).
                              When any of the special size papers is specified for U3, the paper may be used as a special size paper for U3 (universal cassette). 2
                              settings, set it to 35: Folio, on the control panel FLSC will change to FOLIO.
                              Actually FOLIO = 210 X 330 mm and FLSC = 215 X 330 mm.
                              Still in Level 2, press OPTION > BODY > ORG-FLSC > change from 0 to 2.
                              You can also try ORG-A4R > change from 0 to 1.
                              Turn OFF then ON.
