canon ir 6570 5070 5075 total dead help help.............
  • ikbal
    • Apr 2014
    • 22
    [Electrical] canon ir 6570 5070 5075 total dead help help.............
    I have three machines with the same problem ir 5070 5570 & 5075 initially issued a code E004 engine, but now when the green lever on my Rev 1 unit, electric die in my store all ........!!!!
    when I unplug the cable j130 on dc control canon ir 5075 engine life while releasing code ....... can you help me solve this problem ............... thanks .... .........
  • ikbal
    • Apr 2014
    • 22
    Re: canon ir 6570 5070 5075 total dead help help.............
    sekarang saya tahu, kesalahan terjadi pada transistor pada Power supply IH (Indonesian)
    Now I know, the error occurs in the power supply transistor IH (english)
    dimana saya bisa mendapatkan transistor gt60n321??????
    dengan harga murah!!!!!!!!!!!!!!!!(Indonesian)
    where can I get a transistor gt60n321??????
    with cheap price!!!!!!!!!!!!!!!!(english)
    • northernlife
      • Sep 2011
      • 847
      If you leave the copy/process tray out and power cycle the machine do you see the canon logo at all? Does it get past that point?
      • Canuck
        Tech Specialist
        • 1713
        Clear the error and replace the main thermistor assembly(2 thermistors). Replace them all the time myself. Poor design...and induction heating is not very forgiving...thin roll does not hold heat...
        • ikbal
          • Apr 2014
          • 22
          yes I have been through the process .. the engine off when the green lever is increased.
          • ikbal
            • Apr 2014
            • 22
            what do you suggest I've been trying to do, and I also have tried to change their IH board .. but still the same ........ even the IH board also damaged .... like there is a short-circuit.........................whyyyyyyyyyyyyyyyy yyyy
            • danno
              • Oct 2010
              • 15
              Check the fuser blocks male and female for very small pieces of jammed paper.Customers sometimes close the unit and a piece of paper shreds into the contacts
