ir5070
  • pnagar9000
    • Aug 2025
    ir5070
    Hi guys, I am new to this forum.
    I am getting a Jam code 94, it seams like the DADF sensors are indicating james. can not see any paper inside the ADF.
    I flashed the machine with the new firmware, no luck.
    I replaced the reader controller, no luck
    any inputs appreciated
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    The sensors that generate the code are PCB2 the Post separation sensor pcb, PCB3 the Read sensor, PCB4 the Delivery/reversing sensor pcb.
    In this particular case the tech had to replace both PCB2 and PCB4. All three sensors have the same part number FM2-1022-000.
    Thats all that i found in the knowledge base.Have you tried to check them thru the I/O mode?
