copy or print in black half bad (irc3220)
  • cesarkazu
    • Jun 2012
    • 28
    hi, friends
    I have a problem I can not solve in my canon irc3220, black is failing in its half page, toner and drum is ok
  • apollo
    • Mar 2008
    • 182
    Re: copy or print in black half bad (irc3220)
    when you say toner and drum ok
    whats the drum life
    are you using original toner ??
    Need more info
    does problem exist on print or copying ?
    pg10 sample would be useful
    • teckat
      • 16083
      Originally posted by cesarkazu
      hi, friends
      thanks[ATTACH=CONFIG]24786[/ATTACH][ATTACH=CONFIG]24787[/ATTACH]
      post a PG10 test print
      • cesarkazu
        • Jun 2012
        • 28
        problem solved was the black drum, I pulled out and polishing cloth
        thanks friends
