clc 5151 network problem and print quality
  • Rudi Hattingh
    • Aug 2012
    • 16
    #16
    Re: clc 5151 network problem and print quality
    got the problem it is the memory in fiery. but now i have a new problem my black do not print properly see sampel
    • Rudi Hattingh
      • Aug 2012
      • 16
      #17
      • teckat
        • 16083
        #18
        Originally posted by Rudi Hattingh
        [ATTACH=CONFIG]24829[/ATTACH]
        READ--------------------------
        iRC5180_Color_Shift_Prevention _&_Correction.pdf
        • Rudi Hattingh
          • Aug 2012
          • 16
          #19
          Ricoh Namibia could not fix this unit there was a mouse in. got it going on the pc my prints is just not good. did all the celebrations but no luck. do not know what there tech did whit the settings. the custome said i must get rid of the printers. but i like a challenges. look like i am starting to win. well it is only the print quality now
          • Rudi Hattingh
            • Aug 2012
            • 16
            #20
            hi
            some where i read of putting in each laser units values. do you now how. this unit was off for a year. want to check if all values is correct. did the laser change and center the gear but it did not help. how do you print a p print in service mode.
            • teckat
              • 16083
              #21
              hi
              ---_------
              Go and remove ITB UNIT> U will have to remove ITB sheet\ and do a cleaning\
              If someone cleared printer settings without saving a P PRINT of DCON\RCON settings-- u have a Major headache on your a hands --
              Time to buy a Manual Now
              • Rudi Hattingh
                • Aug 2012
                • 16
                #22
                hi have the German service manual. set the laser settings tested all ok.
                thank you for your help. hope i can help you at a time on a mimaki, or mutoh or samsung printer.
                thans again.
