how to fix sticking start up for canon ir2318L
  • Burentugs
    • Aug 2025
    how to fix sticking for canon ir2318L when staring up?
  • teckat
    • 16083
    Re: how to fix sticking start up for canon ir2318L
    pls[ATTACH=CONFIG]24864[/ATTACH]
    Blue Screen of Death
    bad DDR Module
    bad Image Processor
    Procedure after Replacing the Image Processor PCB
    If you have replaced the image processor PCB with a new one, perform the
    following operations:
    - Using the user support tool, download the latest firmware (System/Boot).
    - Input the all value printed on the service label affixed to the rear cover.
    Make the following adjustments:
    - Correction of output between CIS channels
    1) Enter the service mode.
    Sequentially press the Additional Functions, # key on the operation panel.
    2) Using the upper/lower arrow keys on the operation panel, select "Test".
    3) Press the OK key.
    4) Using the upper/lower arrow keys on the operation panel, select "Scanner
    test".
    5) Press the OK key.
    6) Using the upper/lower arrow keys on the operation panel, select "CS Output
    Test".
    7) Press the OK key.
    8) Select "Yes" and then press the OK key.
    After completion of the above steps, contact sensor output correction will be
    performed and parameters will be set automatically.
    - Read position adjustment (Stream reading: Only when the ADF is installed)
    test".
    6) Using the upper/lower arrow keys on the operation panel, select "CS Position
    Test".
    8) Select "Yes" and press the OK key.
    The optical system starts scanning. Several seconds later, automatic adjustment
    of the reading position finishes and "OK" appears.
    • Burentugs
      how to download the user support tool,latest firmware (System/Boot)?
      • teckat
        • 16083
        call on a Canon Trained Support Tech in your area
