I recently purchased some IR5000S machines from a copy center. They were all using card readers, but I want to reset them to work normally without any card readers. When you start the machine, it says "you must insert a control card". I can get into the service mode, but I do not know how to reset the machine to run normally without having to use a card reader. If anyone knows how to do some sort of master reset to the default settings that may help or any other suggestions would be great. Thank you.
I haven't seen the control cards in ages!
The control card module plugs into the plug in the operation panel. If you are lucky the installer left the 4 pin jumper plug in there somewhere. Just unplug the control card module and plug in the jumper. I'll have to look at the manual to see if there is anything in the service mode that needs to be changed (but I don't think so).
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
NickR
thank you for the info, I will try that when I get into the office tomorrow. I appreciate your help.Comment
DVN
Re: you must insert a control card
To access service menu press starhead (additional function key), 2 & 8 (together), starhead.
Press starhead, 2, select "copier", "option", select "ACC", select "CC-SPSW", press 2 (to activate) or 0 (to deactivate), press OK, press yellow "Reset" to quit.
