Can I swap an adf from a canon image runner advance c5051 and a c5045?
Canon adf
Re: Canon adf
Thank you for your replies. I have switched the two feeders and the adf initializes when powered on but I can not get the machine to take the run the orginals through the feeder. It keeps copying off of the glass. I checked the connectors and it still only scans off the glass. Any thoughts?Comment
Re: Canon adf
you might need to tell the machine that it has a feder unit, or tell it that it doesn't, then tell it it does again.
go to:
service mode> Copier>Option>DNC-SW>W/SCNR set 1 to 0
turn off machine
unplug reader unit connector
turn on machine
go to above option and set value to 1
turn off machine
plug reader unit back in
turn on machine
**what this does is tell the machine that it doesn't have a reader unit (so don't expect the CCD to do anything at boot) and then tells the machine that a reader unit is installed.
this might resolve the issue your having.Comment
Re: Canon adf
