Canon iR3300---Blank copies.
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    [Electrical] Canon iR3300---Blank copies.
    Hi Guys, there's this machine which has given me so much trouble that its making me look like sort of a ''Paper-Tiger'' technician, despite all these years of experience! It's iR3300 giving BLANK copies. It all started with the trailing edge of the copy papers folding as it passes through the fixing unit; in both main and sub scan directions, but with images available (according to the m\c's operator). Then all of a sudden the images disappeared and it started spitting out blank sheets.
    This is what I have done so far, over the last three days, very devotedly: Checked all the high voltage contacts for developing unit, drum unit & transfer rollers to ensure that they are making good and proper contacts,
    checked and confirmed that the door mechanism really operates the laser shutter mechanism. For the benefit of doubting Thomas's, I went an extra mile and tested the following units, physically, by substitution, in another working machine: the Drum unit, the developing unit, the Laser unit, the Transfer roller, and last but not least, the Composite power supply unit. I was fortunate enough to have another customer with a similar model (ir2800) a few yards away from this machine, and he gave me total access to his machine to enable me to do a physical substitution of the above parts, one at a time. The units all tested 'positive', working very well in this machine.
    Next, I removed the fixing unit...(folding trailing edge of the papers), and plugged it in this other copier, it works very well, no folding papers. I suspected that a missing HV could be causing this paper folding. NOTE: I then swapped the fixing unit, the one from the working copier, also started folding trailing edge of the papers when i put it into the faulty copier., meaning fixing unit has no problem. I confess that the only unit which I did not test by substitution is the DC controller....another suspect related to this fault.
    I am now confused, years of experience in this field not withstanding, this particular fault has really been my worst encounter! Let me hear from you Gurus, if there's any magic formula to this dilemma.
    Thanks in advance.
  • teckat
    • 16083
    Re: Canon iR3300---Blank copies.
    image leading edge sensor {PS12} may not be detecting paper. This sensor tells the Laser when to start writing.
    Check connector J312 on the DC Controller for good contact, also cut the wire ties associated with J312.
    Cut and replaced all wire ties from PS12 to the DC Controller. Also removed wire ties at the Registration sensor {PS10}.
    if u have the P PRINTS (
    door specs) Before replacing the DC Controller, perform a DCON and RCON clear.
    then re-boot machine./
      • 23010
      Does the exposure lamp illuminate?
      Is the developing unit cammed up close to the drum unit?
      Canon's have a few interesting quirks. If the exposure lamp does not illuminate brightly enough or quickly enough, the first copy may be black, but the following copies will be blank. =^..^=
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        Your prints will be blank if the developing cylinder is not rotating. Try to replace the developing clutch CL3 and good luck.
        Rachid
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • Oct 2010
          • 860
          Thank you blackcat for your input. The lamp lights up well, but even then, the in service mode, COPIER>FUNCTION>MISC-P> PRINT give blank copies. I am yet to tackle the problem again.
            • Oct 2010
            • 860
            Originally posted by Rachid.Akli
            Hello,
            Rachid
            Thanks Rachid for your input, the developing cylinder rotates very well; I cleaned a portion of the cylinder off toner, or turned the cylinder in opposite direction to form thick magnetic brush, then reinserted into the machine; the magnetic brush reformed to normal level, indicating cylinder rotates. Would it still be necessary to try replacing the clutch?
              • Oct 2010
              • 860
              Thanks teckat for your input, I will go back to the machine again this week, try the leads you have given me and post a feedback to the forum.
              • Brian8506
                • 1665
                Definitely check specs. Had a machine awhile back that would default laser and hv specs to 0
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  Hello,
                  the clutch seems to be OK. What about the drum rotation?
                  Rachid.
                  • danno
                    • Oct 2010
                    • 15
                    only time I have seen blank copies on this unit the dev cam mechanism wasnt camming the dev against the drum properly
                      • Oct 2010
                      • 860
                      Hello,
                      Rachid.
                      The drum is rotating, i even made a mark on the front edge of the cylinder with a marker pen in order to make a proper observation of its rotation. The developing cylinder is locking\engaging very well with the drum unit.
                        • Oct 2010
                        • 860
                        Solutions update. Well, what else can i say? Complex problems, Simple solutions! I got the door specs sheet and decided to reset all the values to initial factory settings, and the machine is now spitting out very clean copies. But before the adjustments or resets, the values i found in the machine were totally weird! Completely so out of specifications that i couldn't figure out exactly how the values went so 'berserk' out of tolerance limits.
                        Thank you all guys for your support.
                        • Brian8506
                          • 1665
                          Had it happen once. That's why I suggested it. It actually did it twice. Machine no longer in the field so I don't know why it did it. Happy ending
                            • 23010
                            ... But before the adjustments or resets, the values i found in the machine were totally weird! Completely so out of specifications that i couldn't figure out exactly how the values went so 'berserk' out of tolerance limits.
                            I've always been fairly cautious about making adjustments in service mode. For example, writing down the initial values so it can be restored to original settings if needed. Not everyone is this cautious. Back when the machines had VR's, there was at least one tech that had to tweak every VR, whether he knew what it was for or not. =^..^=
                            • Brian8506
                              • 1665
                              Fortunately that machine probably had its birth certificate under the cover inside the door.
