Canon ir2270
  • mramlawi
    • Jul 2011
    • 838
    Canon ir2270
    Dear all ,
    i have a problem in IR2270 machine ,when im trying to make a 2 sided copying the machine copied 2 documents and the 3rd copy stucks in the duplex also the machine gives on the middle lower in the screen printing and the machine is makein rotation at the moment i wonder if this happen with any one ,no error codes also it didnt gives jam , just when i clicked on the system monitor copy details (error).
    Distinguished road makes you jewel in rough
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon ir2270
    Originally posted by mramlawi
    Dear all ,
    There will be a Jam Code - press ADDITION FUNCTIONS > 2+8 > ADDITION FUNCTIONS to access Srv Mode > COPIER > DISPLAY > JAM and POST the Jam Code, we may be able to assist from there.
    Cliff.
    • mramlawi
      • Jul 2011
      • 838
      Re: Canon ir2270
      Cliff.
      0A05 \ 0205 \0A08
      • ernesto
        • Oct 2011
        • 430
        it looks familiar with a canon ir 2230 I set the paper in a4r and it is wotking right
        the customer agreed with that.
        I think I had replaced, dc con, right door, hd and updated firmware but the problem was still there..... the machines is working ok since two years in a4r .... ...
        if you solve the problem can you tell me please?
        Good luck!!!!
        • Blizzoo
          • Aug 2013
          • 610
          Re: Canon ir2270
          Did you check those noise dampers under flapper fixing delivery if are sticky?
          • mramlawi
            • Jul 2011
            • 838
            Re: Canon ir2270
            Good luck!!!!
            i agree you dude ,i also changed HDD ,and the Bypass Door still same problem i will try to make it A4R ,actually im thinkin to change DC Con as u said but i didnt try it yet .
            abt the sensors everything is changed
            • mramlawi
              • Jul 2011
              • 838
              Re: Canon ir2270
              thats what exactly happened with me when i try to make a duplex copy and at the copy no 4 its gives printing ... as the figure showed
              • kstan268
                • Apr 2012
                • 85
                Re: Canon ir2270
                [ATTACH=CONFIG]24988[/ATTACH][ATTACH=CONFIG]24989[/ATTACH]
                I had the same problem recently ..do you had solution of this problem already??
                • kstan268
                  • Apr 2012
                  • 85
                  Re: Canon ir2270
                  I solve this problem by replaced a electromagnetic clutch FH6-5005-020 work perfectly
