I am getting this jam code with the information from previous posts I have narrowed down the cause to the front door sensor the toner door. While making copies I watch that sensor in service mode IO and start to see it flip flop from 1 to 0 intermittantly and then a jam occurs. I have tried to switch that sensor with the waste toner sensor and get the same thing. the actuator on the door is ok. I checked the grounding plate spring on the reg roller also. I am trying to find a circuit diagram so that I can trace the wiring of that sensor. I have the service manual but there is no circuit diagram in it. The older model machines had circuit diagrams in the service handbooks. I have not been able to find it for this series of machines. Any help would be greatly apprieciated.
Thanks.
Thanks.
