Canon Faxphone L80
  • ronmay
    Canon Faxphone L80
    I have a canon fax L80 that refuses to recognize the cartridge. Tried another cartridge without success. I have no manual so am shooting blind.
    Any suggestions?
    Ron
    • 23007
    I've only worked on a couple of these, and not for cartidge problems.
    The faxLC9000 was well known for giving toner empty indications, when the cartridge was full. Inside the cover over the cartridge there was a plastic feature that pressed two levers to raise the toner sensor up to the bottom of the cartridge. The fix was to install a few #10 flat washers between the feature and the cover (the feature was screwed on).
    Based on this, I would look into exactly how the toner sensor is positioned, and if it has a mechanism to raise it, and how. I would doubt that the sensor itself was faulty, just the positioning.
    • nmfaxman
      • 1702
      Press function then #.
      Service mode.
      Arrow over to reset.
      Do a Full reset.
      I have a lot of these and they tend to get logic locks.
      • ronmay
        Canon faxphone L80
        Turns out it WAS the sensor. I took it out and was able to activate it with a weak magnet. The cartridge had no affect. I adjusted the ferrite core inside the sensor just a tad and it started working.
        Thanks for all the help.
        • lkrsardis
          • Dec 2007
          • 316
          sensor
          Wow. Good fix man.
          Like the United States Postal Service It's a miracle it works!
            • 23007
            Excellent!
            • icehelda
              Canon Faxphone L80
              Hi
              I seem to have broken my fax the wheel that pushs the pages through snaped in half when i was sending a fax. If any one has an info on how to fix it that woild truly be great.
              thanks
