Red ground wire from fixing film unit
  • brunno1968
    • Apr 2014
    • 19
    Hi, I just re-install the fixing film unit from my ir2018 but i don't remember where does this ground wire goes. This is the wire that you can see page 8-9 figure 8-14 and 8-15 from service manual.
    Thank you
  • Brian8506
    • 1666
    Re: Red ground wire from fixing film unit
    There's a small plastic mount that that slips onto and I believe it makes contact at that point. Take the fuser out and you should see it. Hard to explain without being there.
    • brunno1968
      • Apr 2014
      • 19
      Just an other picture to show you where i connected one sideDSC_0038.jpg but for the other side ??
      Thank you for your help
      • brunno1968
        • Apr 2014
        • 19
        Does anyone can help me to connect this wire ?
        • northernlife
          • Sep 2011
          • 847
          see attached photos
          • brunno1968
            • Apr 2014
            • 19
            Thank you very much. I really appreciate your help.
            Have a nice day, Bruno
            • brunno1968
              • Apr 2014
              • 19
              I re-install all parts. Turn on power and....error system E0003 and error E000 !
              What is the problem ?
              • northernlife
                • Sep 2011
                • 847
                You clear the error?
                • brunno1968
                  • Apr 2014
                  • 19
                  No , i don't. I know that, service mode : *, 2 key, 8 key, * after i am going to clear, err but after that ???? to clear the error display, what is the button ????
                  • brunno1968
                    • Apr 2014
                    • 19
                    I don't know how to clear the error ! I need help !
                    • northernlife
                      • Sep 2011
                      • 847
                      Looking for it in the manual, seems there's just the clear and then you can clear the coin reader codes or whatever. Only thing I could think of was to do a clear all instead. Sorry it's been quite some time since I've had to service these units.
                      • brunno1968
                        • Apr 2014
                        • 19
                        Hi, when i am doing this :
                        Maintenance/parts counter all clearExecute service mode > CLEAR > COUNTER to clear all maintenance/parts counters.
                        - Counter clear on parts replacement
                        Press the numeric keypad key 0 after displaying the counter for a part just replaced, and the counter will be cleared individually.
                        Nothing happened, only bip-bip bip !!!!! even if i turn off and on the ir2018
                        I am pretty sure that i am doing someting wrong but what ???
                        • northernlife
                          • Sep 2011
                          • 847
                          you're clearing the durable parts counter, try the all. you will lose all settings back to default.
                          • brunno1968
                            • Apr 2014
                            • 19
                            So i need to export the user data before clearing all ?
                            Sorry for all question. I am not familiar with copier...habitually i am fixing photographic minilab.
                            Thank you very much to taking time to answering my questions !
                            • northernlife
                              • Sep 2011
                              • 847
                              If you can, sometimes the old ones are locked down but worth a shot. Np at all. Sorry I'm not more familiar with them.
