print out not stick
  • Matoku
    • 173
    print out not stick
    Hello everyone.
    I have one IR2870 with the image not stick to the paper, I mean when I rub it, the toner can be removed from the paper.
    I have try change these parts
    Heater file Unit ( whole unit ) genuine part.
    pressure roller
    ac drive pcb
    dc Controller Pcb
    power supply pcb
    The fix-temp set to 7 but still not satisfied.
    anyone can give me an idea?
    Thanks in advance.
    • 23009
    Re: print out not stick
    What type of media, at what media settings? =^..^=
    • mramlawi
      • Jul 2011
      • 838
      change the cylander and your problem will solve
      Distinguished road makes you jewel in rough
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        Verify that the right door closing mechanism works correctly: When closing the door the fixing pressure roller must come in contact with the fixing film (with enough pressure). Have a look on the pressure roller bushings and the film installation.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • RRodgers
          • Jun 2009
          • 1947
          Blahhh!!! Just use some hairspray after the copies come out. That should hold it down. I would recommend Aquanet.
          • northernlife
            • Sep 2011
            • 847
            most def what rachid has suggested. If it's one tooth off it'll give you 0207's and poor fixing.
            • Matoku
              • 173
              Hello,
              Sorry for late to check his post, By the way my problem already solved, the solution is by changing new packing of paper in deferent paper brand.
              I think that paper was low quality
              Thanks all
