irc3380i
  • akm
    • Sep 2012
    • 155
    [CQ] irc3380i
    Dear/CopyTechTeam,
    i face a problem with IRC3380I that the screen of toner cartridges remainder show full but actually the cartriges not full
    thanks
    akm
  • vamoursly
    • Sep 2011
    • 273
    Re: irc3380i
    Toner detection can be found if you look in the SM for this model, personally I have never found the IRC model very accurate in being able to represent what is actually in the toner cartridge, I prefer to weigh them in my hand to judge how full they are;
    I am sure teckat will be able to give you a more detailed explanation when he is online in his timezone.
    V
    • Simons
      • Jun 2008
      • 490
      Re: irc3380i
      there was a tech pub about this. Canon said that the user needs to actually cycle through the copier screen instructions for toner replacement when putting in a new toner. ONLY by doing this will you get an accurate read on the consumables screen. Of course the machine runs with sensors and would report low via sensor and out via sensor. The level on the screen is not that important and will never be close and just a guess if the procedure is not followed. ( there is no toner sensor in the actual container, that's why this is important )
      • northernlife
        • Sep 2011
        • 847
        Re: irc3380i
        correct, if toner never hits zero and the user doesn't follow the steps exactly it'll never clear.
