ir1025 drum replacement .... am I missing something?
  • dpackman
    • May 2014
    • 7
    I need to replace the drum on an imagerunner 1025. I think I've done this before, but it seems welded on now and I can't get it out. This reference suggests that I should just be able to pull it out using the two handles. Am I missing something?
    Canon Knowledgebase
  • Cycle Clutch
    • Feb 2013
    • 25
    Re: ir1025 drum replacement .... am I missing something?
    You probably have a Katun drum in the IR1025. Everyone I've had to pull out, was stuck. Good luck.
    • copier tech
      • 8192
      Yeah they are a tight fit, don't be scared give it a good hard tug!
      • canonbundy
        • Jun 2012
        • 607
        Canon Knowledgebase
        Lower the L/H door & check the black plastic lever/arm isn't broken as this releases the Drum Unit to enable the smooth removal - if broken you can release by pulling the remaining part of the lever down.
        • dwarf
          • Oct 2012
          • 168
          I'm having the same problem...exactly where is the lever that you speak of?...I'm afraid that a good hard tug will bust something...
