ir5065
  • akm
    • Sep 2012
    • 155
    [Jamming] ir5065
    Dear/ CopyTechTeam,
    Please i want your help to solve the problem with IR5065 that indicates the screen of jam that ' open the front door , push out the unit 2 ' i check ed for any paper jam and check the connector for the unit but still appear the message jam code 0A08 PS33 .
    thanks
    akm
  • canonbundy
    • Jun 2012
    • 607
    Re: ir5065
    Originally posted by akm
    Dear/ CopyTechTeam,
    thanks
    akm
    Symptom
    Unit will not show warm up in service mode and after booting up, the Insert Drawer #1 message shows when the front door is opened. Checked service mode I/O for copier and PS33 did not change state. Even though no paper has been fed, there are 0A08 codes in the jam history.
    Cause
    Found a pinched wire in the duplex tray connecting PS33 to rear connector.
    Action
    Replace the Duplexing Path Cable (FG6-5467-000).
    • Simons
      • Jun 2008
      • 490
      Re: ir5065
      The most likely cause for " insert the unit " is that the horizontal motor needs replaced in the duplexer. The gear cracks and causes weird stuff. Believe it or not. I cant remember if a jam is caused or shown but insert the unit message could cause a jam.
      • teckat
        • 16083
        Re: ir5065
        Dear/ CopyTechTeam,
        thanks
        akm
        Message: Reset Unit Two
        The absence or presence of unit two is determined by the detection of the horizontal registration assembly.
        Check the horizontal registration motor (M16).
        Check if the drive gear is cracked on the motor, causing a bind in the assembly.
        The part number for M16 is FK2-0144-000.
        • akm
          • Sep 2012
          • 155
          Re: ir5065
          thanks Eng.Teckat
          i will check the motor m16 , the drive gear ,ps33 and i will feedback the result
          thanks
          akm
          • akm
            • Sep 2012
            • 155
            Re: ir5065
            Dear/Eng.Teckat
            I want to inform you that the problem is solved by reseat all cables of unit 2 and change of sensor PS33
            THANKS
            Akm
            • teckat
              • 16083
              Re: ir5065
              Dear/Eng.Teckat
              THANKS
              Akm
